Hello Guest it is November 12, 2026, 02:13:48 AM
Author Topic: How do I edit the VB?  (Read 22982 times)
« on: June 26, 2009, 11:27:13 AM »
Yep, but I don't know how to change the VB Scripts. The DRO fonts are kind of fatter then the original. Other then that, perfect!
« Last Edit: June 27, 2009, 04:05:13 AM by Chaoticone »
« Reply #1 on: June 27, 2009, 02:25:36 AM »
Hi sunmix,
select the object with the vb-script. For example in the 1024.set the button "Ref all home". When you double click the column "value" of the line "Execute code" in the property dialog an editor is started where you can edit your vb-script.  To terminate editing use the file menu. You have the following alternatives:
open files, save file as, with those options you can load data from your disk or store data to your disk.
use data and close -> the edited data is move to the screen.set file and the editor will be closed.
ignore data and close -> all new / changed data will be ignored, thus the code from the screen.set is unchanged and the editor will be closed.
Klaus
« Last Edit: June 27, 2009, 04:04:18 AM by Chaoticone »
The brain isn't a soap, it doesn't shrink when used.
