Hello Guest it is November 25, 2026, 01:15:51 AM
Author Topic: Galil HELP DMC-1842  (Read 63098 times)
Re: Galil HELP DMC-1842
« Reply #20 on: August 12, 2012, 09:03:24 PM »
RE:GALIL DMC-1842 /ICM2900/MACH
During the studying of the galil and mach 3 doc. im having trouble understanding how mach3 communicates to galil. I purchased camsoft package 2 yr ago but have not had the drive to complete ,then licensing fees are judicious. my servo drives are servo dynamics pmw needing 10v analog and spindle yaskawa needs 10 v analog . i am connecting encoders ,drives and spindle to icm2900. im looking for details on how to do this . can you give me direct on where/what to study.
thankyou john
« Reply #21 on: August 14, 2012, 08:02:00 PM »
If you don't have tons of experience, keep it simple for now. I have to find my manuals but it is relatively easy, Galil has configurable pins, map them in Mach and you're all set.  I would recommend step/direction to the drives for the time being and a simple pot to control the spindle.  Get the machine running and then tweak.
« Reply #22 on: August 14, 2012, 08:12:40 PM »
thankyou so much , that is what im doing ..tell me can i hook up the computer/galil/icm2900  and power supply to icm 2900 then monitor analog voltage output befor hooking to the drives and spindle ?
they used to call the machine the beast...so maybe i should change my handle...
« Reply #23 on: August 17, 2012, 06:59:59 PM »
YOU KNOW READING IS THE KEY TO ALL KNOWLEGE.....ALL MY QUESTIONS  .......I HAVE BEGUN STUDYING THE GALIL PLUGIN PDF AND MACH3 INSTALL PDF AND I CAN SEE 99 PCT OF THE ANSWERS ARE THERE .......YOU GUYS AT MACH3 HAVE DONE A FANTASTIC JOB ....NOW JUST TO READ.STUDY AND UNDERSTAND WHICH IS MY CHALLENGE AT 67 YR OLD....... THANKYOU..........
« Reply #24 on: June 23, 2013, 04:33:34 PM »
I wonder if any one help me about using DMC-1832 Or DMC-1842 with Mach3 and configure MPG unit attached with system and the motors type areservo motors with (A+,A-,B+,B-,C+,C-) encoders will connect to controller.
Note: the old controller DMC-9542 , I am planing to use DMC-1842 because the old one not support the Galil plugin and not compatible with Mach3.
The most important question I want to know , If I will use DMC-1832 in this machine , I will need any special coding ?
OR I will use Galil plugin to configure this system with Mach3 without needing any coding ??
