Hello Guest it is November 11, 2026, 06:03:56 PM
Author Topic: What are the OEM Code of LEDs used in "Port 1 Pins current State"?  (Read 22039 times)
Hello to all. Want to know the correspondence between the number of pins of LPT1 with the OEM Code (Led) 139 to 160. Thanks in advance. Giordano
Re: What are the OEM Code of LEDs used in "Port 1 Pins current State"?
« Reply #1 on: June 24, 2009, 05:43:18 PM »
137 - 160
« Reply #2 on: June 24, 2009, 05:51:13 PM »
Hello Hood. Thanks for your reply. Let me explain better. For example, the LED pin 15 of LPT1 is OEM Code 140. Thank you.
« Reply #3 on: June 24, 2009, 05:54:50 PM »
Sorry, late here and wasnt reading properly.
 Well afraid I do not have a clue, never worked out what they represent, then again I have never really tried to ;D
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #4 on: June 24, 2009, 08:45:01 PM »
Hi, Giordano
The only one's defined/that work are are Input pin's 10, 11, 12, 13 & 15, As far as I know.
Chip
« Reply #5 on: June 25, 2009, 05:33:45 AM »
Hello, Chip. Making a new screenset Italian and wanted to monitor the activities of LPT1. Thank you. Giordano
Offline Chip
  •  2,055 2,055
« Reply #6 on: June 25, 2009, 02:22:28 PM »
Hi, Giordano
I did one like this, It would be nice if they were all working.
Chip
« Reply #7 on: June 26, 2009, 07:14:34 AM »
Hello, Chip. Very well done. Do you have a particular version or you have modified the original screen for Mach3? In my version, the 3,042,020 pins are not numbered and inputs 10,11,12,13 and 15 are arranged differently. You could tell me what the Code of OEM led each pin from n. 1 to n. 25 or, better yet, send me a copy of your screen? Regards. Giordano
Offline Chip
  •  2,055 2,055
« Reply #8 on: June 27, 2009, 07:29:20 PM »
Hi, Giordano
It's the standard 1024 screen set, I used a copy of it and "Screen4" to move the led's around and added items I wanted.
Hears 2 work-in  progress Screen set's I'm working to help "Mostly" new Users figure out what "Mode" Mach is in, 1 for Mill, 1 for Lathe, Both have a pop-out lathe Pendent at this point, You need to install the bitmaps in C:\Mach3\Bitmaps\Millbitmaps folder.
Have Fun, Chip
« Reply #9 on: June 28, 2009, 01:10:39 PM »
Hello, Chip. I you were a great help. Thank you very much. Regards, Giordano.
