Hello Guest it is November 10, 2026, 01:52:43 AM
Author Topic: turret tool macro  (Read 10565 times)
turret tool macro
« on: June 24, 2009, 08:22:06 AM »
hi all. i am having difficulty getting a toolchanger macro to work. here is how it has to function.jog the x and z axis to a safe position,activate output19 which switches on an air solenoid, jog a axis to a set position 45,deactivate output 19, activate output 20, deacivate output 20.
here is my macro.
DeActivateSignal(Output20)  " make sure solenoid is realeased.
code"z1x3"                          " jog to safe place for toolchange
While IsMoving ()
Wend
ActivateSignal(Output19)    " turn on solenoid to raise turret
code"g4p1"                        " wait 1 second
code"g0a45"                      " rotate turret
While Ismoving ()
Wend
DeActivateSignal(Output19)   "release solenoid
code"g4p1"
ActivateSignal(Output20)      " turn on solenoid to retract turret
code"g4p1"
DeactivateSignal(Output20)    " release solenoid
the code skips over the deactivate signal. if i run the outputs individually in mdi, they work . pushing reset deacivates.
the machine is a hardinge chnc3. the turret is driven by stepper motor.
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: turret tool macro
« Reply #1 on: June 25, 2009, 02:37:25 PM »
Could you try replacing
Code: [Select]
code "g4p1"   with
Code: [Select]
sleep(1000) and let me know if that fixes it.
« Reply #2 on: June 25, 2009, 08:32:02 PM »
thanks, i will try it tomorrow.
« Reply #3 on: June 29, 2009, 08:07:02 PM »
thanks, now it works.
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #4 on: July 01, 2009, 04:19:34 AM »
Great to hear
