Hello Guest it is September 29, 2026, 08:42:28 PM
Author Topic: key grabber issues  (Read 14874 times)
Offline eloid
  •  33 33
key grabber issues
« on: June 19, 2009, 10:55:04 PM »
i have my game pad and installed driver etc, got it workng now, when i reboot mach and pc....
(phiips brand game pad) it does not work untill i lauch the keygraber program why?
i saved the config with the default name, in the default location.. am i missing something
Re: key grabber issues
« Reply #1 on: June 20, 2009, 03:10:00 AM »
I have never used a gamepad but I do use keygrabber with a keyboard emulator on my Bridgeport so I am thinking it is a similar thing.
 What I have is my shortcut to start Mach is actually directed at the Kegrabber.exe and keygrabber is then set to open my Mach profile automatically. That means when I click on the shortcut for Mach it opens keygrabber then it is keygrabber that opens Mach.
To do that you right click on your desktop Icon that you use to Start your Mach profile and then choose properties. In the target field it will say something like
C:\Mach3\Mach3.exe /p Mach3Mill
If you change that to say
C:\Mach3\KeyGrabber.exe /p Mach3Mill
Then when you double click it keygrabber will start and then automatically start Mach.
« Reply #2 on: June 20, 2009, 04:11:18 AM »
It is recommended that you DO NOT install the drivers that came with the gamepad.
Offline eloid
  •  33 33
« Reply #3 on: June 20, 2009, 04:00:43 PM »
will try that...thanks
