Hello Guest it is November 25, 2026, 07:15:09 AM
Author Topic: Jog keys switch themselves on Mach startup  (Read 11561 times)
« on: June 19, 2009, 08:09:10 AM »
New Mach user here so I apologize if this has been asked 400 times before.  When I first startup Mach, one of the first things I do is jog the machine around to make sure I've got a good connection.  I have been finding that on startup, I'll try to jog the Y axis in the positive direction and what will happen is the Z axis will travel in the negative direction?!  It seems to cure itself if I jog the Z and X axis around and then everything works as it should.  As I test, I opened up Mach and didn't touch any jog keys, just loaded up some test G-code and ran the machine.  Sure enough, Mach thought the Z axis was the Y and moved it accordingly causing some undesirable results.  I stopped the program, jogged all of the axes around until everything was "normal" and reran the program and it was fine.
Any thoughts?
Re: Jog keys switch themselves on Mach startup
« Reply #1 on: June 19, 2009, 12:58:17 PM »
That should not happen, are you using any external devices such as the shuttle to jog?
 Can you attach your xml please.
« Reply #2 on: June 19, 2009, 01:03:45 PM »
No shuttle.  I did have the XBox 360 controller plugin up and running, but when I upgraded Mach, I don't think I ever re-enabled it and the controller has been unplugged.
I can attach my XML as soon as I am near the machine later today.
