Hello Guest it is November 22, 2026, 07:01:57 AM
Author Topic: Strange Mach3 stoppages in plasma mode  (Read 16513 times)
« on: June 18, 2009, 07:38:52 AM »
I have a Dynacnc plasma/router with a Dyna6000 series controller. Mach3 ver 1.9. The torch is a automated Cutmaster 52 with a hand torch.  My problem is the on plasma side. The machine will cut and follow the gcode fine for (usually) 14-20 inches then it trips off (goes into reset mode) shutting everthing down. If I only cut 12 inches and stop, then do a new pierce and start to cut I can go another 12 inches or so, etc etc. Sometimes more sometimes less.   Makes no difference if THC is on or off.
The machine is flawless when cutting wood with a router.
I am at my wits end and about ready to quit the plasma portion all together unless one of you Gurus can point me in the right direction.
Any ideas???
Mike
Re: Strange Mach3 stoppages in plasma mode
« Reply #1 on: June 18, 2009, 08:06:37 AM »
Is there an error message in the ticker line when it trips? Kind of sounds like noise from the torch is causing the limits to trip, setting a debounce interval of 2000 might help, if it does then lower until you get the problem again then increase slightly.
« Reply #2 on: June 18, 2009, 11:01:04 AM »
No message in the ticker, just "Reset" flashing. I'll try to find the debounce area and give that a shot. What is debounce?
Mike
« Reply #3 on: June 18, 2009, 12:33:22 PM »
You will find it from Config menu then General config page, its top right. The Debounce Interval is just the length of time a signal has to be seen by Mach before it acts on it, the time is in micro seconds
« Reply #4 on: June 18, 2009, 12:59:16 PM »
Thanks for your help on this. it turns out it was noise from the current transformer which gives a arc good signal. I bought a automation wire harness that tapped into the pcb board on the torch. I cut my first piece of metal I didn't have to scrap in 9 months.
Thanks for your respondes
Mike
« Reply #5 on: June 18, 2009, 01:01:03 PM »
Thats great to hear :)
