Hello Guest it is November 13, 2026, 08:09:10 PM
Author Topic: Water cooled spindle motor safety  (Read 15961 times)
« on: June 18, 2009, 12:46:36 AM »
Hi, I'm about hooking up my Water cooled spindle motor and I have some concern about safety.
On my old motor, I had a safety switch in series with the motor so when I had a tool change to do, I always disable it with the switch, did not want to rely on Mach3 only.
But with the new motor which have a VFD, as per the manual, nothing can be connected between the VFD and motor.
I want Mach3 to control the on and off of the spindle and when everything is working OK, then I want mach3 to Control RPM too.
But not sure about Mach3 for safety, afraid something happen when my hand are near the spindle in a tool change.
Any advice, Jeff
Re: Water cooled spindle motor safety
« Reply #1 on: June 18, 2009, 01:56:47 AM »
You could cut the power to the VFD itself but obviously the capacitors in the VFD would take a while to discharge. There may be an enable signal for the VFD which you could use with an external button, this will still rely on the VFD working correctly internally to make sure it does not allow the spindle to start but should be very reliable.
« Last Edit: June 18, 2009, 02:45:33 AM by Hood »
« Reply #2 on: June 18, 2009, 02:39:22 AM »
Hi Hood, as usual, always an answer for everything.
Thanks for your support, will see if this can apply to my VFD.
Again, Thanks
vmax549
« Reply #3 on: June 18, 2009, 02:03:30 PM »
ONly 2 things I have seen that apply .  A spindle brake to lock down the spindle or a spindle index that is basically a slot and a pin to lock the spindle. IF something went wrong the VFD will trip off.
One setup I saw was simply a wrench in a slot that slid over to engage the spindle flats and it also doubled as the wrench to lossen the spindle nut.
Just a thought, (;-) TP
« Reply #4 on: June 21, 2009, 02:53:04 AM »
As long as you are not stopping the spindle by using the FWD or REV inputs on the VFD and no just turning the spindle control voltage down to 0 you should never have an issue with the spindle starting during a tool change. Not only would mach have activate the output line controlling the direction but it would also have to output either PWM or Step signal to activate the analog board controlling the VFD.
On my mill I have separate relays for FWD and REV and they are interlocked so they can not be operated at the same time. I have never had an issue with the spindle moving even the slightest.
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
« Reply #5 on: June 22, 2009, 02:36:55 AM »
Following on from the last post, you could try having a switch which put a signal on the Forward and Reverse switches of the  VFD. This, on my Omron, shows up as a fault, immediately, and the spindle is dead. As soon as the signals are removed, and replaced by only a Forward OR Reverse the spindle starts again
« Reply #6 on: June 22, 2009, 03:47:11 AM »
Good idea, will give it a try, Jeff
