Hello Guest it is October 21, 2026, 02:51:20 PM
Author Topic: Problem with homing  (Read 10071 times)
Problem with homing
« on: June 16, 2009, 06:55:49 PM »
When I try and home my router Z works just fine, then Y homes fine and when it starts to do X it acts like it is just trying to move the X motor and not the A that is slaved to it. The two run together just fine except when trying to home or reference the gantry in X. I have been through everything that I know to check (even though at this time it is not alot) and can not figure it out. I used the video on setting up the switches and soft limits and reviewed  it again to try and make sure I did not miss anything.
Jimmy
Re: Problem with homing
« Reply #1 on: June 16, 2009, 08:33:56 PM »
Try in the Config menu, under the general config and check the Home slave with master axis
Jeff
