Hello Guest it is October 21, 2026, 07:15:23 PM
Author Topic: Can Any One help Only one direction on y motor for fwd and rev input  (Read 10052 times)
Hi Guys, I have a y motor that only moving in one direction regardless of the command. the Mac3 screen is working correctly but every time a Y command is given (+ or - Ve) the motor only rotate in the + direction Can Anyone Help. Also How do you jog the 4th axis in MAch 3 Mill froom the keyboard. I cannot seem to find the shuttle screen as in the manual.
Re: Can Any One help Only one direction on y motor for fwd and rev input
« Reply #1 on: June 16, 2009, 11:49:47 PM »
Sounds like your either have the wrong pin asigned in Mach for the Dir signal to your Y axis or the wiring is faulty or the port or breakout is not passing the sinal.
Press the Tab key and you will get the pop out screen for jogging.
