Hello Guest it is November 29, 2026, 07:24:27 AM
Author Topic: Kernel speed and brain speed  (Read 7245 times)
« on: June 16, 2009, 04:53:58 AM »
Hello.
Just want to know if the brain speed (number of times / time unit it is run) is in relation to the kernel speed.
I need a sensor to stop an axis, and the axis stops in a random position due to the fact that the brain does not process the input signal at the same time after the signal is high.
