Hello Guest it is October 21, 2026, 08:52:29 PM
Author Topic: THC ON/OFF Button  (Read 14181 times)
Offline mrpeja
  •  114 114
    • Embroidery Machines
THC ON/OFF Button
« on: June 16, 2009, 04:09:57 AM »
I want to toggle THC on and off using macro file.
Does anyone know about witch is the OemButton code equivalent to screen button used for THC on/off, and the associated led code number?
mrpeja
Re: THC ON/OFF Button
« Reply #1 on: June 16, 2009, 12:30:24 PM »
123 for button 24 for LED
Offline mrpeja
  •  114 114
« Reply #2 on: June 16, 2009, 02:35:43 PM »
Hi Hood,
I'm l little bit confused. According to MachWiki (http://www.machsupport.com/MachCustomizeWiki/index.php?title=OEM_Buttons) this is code for torch activate. Or I misunderstand.
I need code for Torch Height Control (THC) activate/deactivate
« Reply #3 on: June 16, 2009, 02:41:05 PM »
That is the OEM codes for the button and LED circled in the below screenshot, is it different ones you are meaning?
Offline mrpeja
  •  114 114
« Reply #4 on: June 17, 2009, 03:21:57 AM »
Hood,
Yes, this is the button I'm meaning.
In this case MachWiki OemCode description is not correct. How to tell to author to correct it?
mrpeja
« Reply #5 on: June 17, 2009, 12:48:27 PM »
I think you can join the wiki and change it yourself. There will however be some updates to the descriptions and oem numbers in the future (I think) so it is possibly not worth it at the moment.
 An easy way to find out the OEM of a button (except the standard ones) is to open the screenset in Screen4 and then double click on the button or LED in question and you will see what the OEM is. Standard buttons such as Start, Stop etc may just tell you that and not the OEM code so the list would need to be referred to for them.
