Hello Guest it is November 10, 2026, 12:09:06 PM
Author Topic: new setp with cnc4pc c23 bob  (Read 40315 times)
Offline eloid
  •  33 33
Re: new setp with cnc4pc c23 bob
« Reply #10 on: June 14, 2009, 11:20:18 AM »
estop and limit switch working now ;D problem was with opto coupler having no power from smooth stepper c23 require
it from smooth stepper or external power..
now i need to get my motors working... there giving me isuues  ???  :o
gecko drives g203s have green leds can hear them power up .. clunk sound, motor have good holding torq.
double checked step and Dir wiring, is OK, Dir from g203 to x Dir on output bob, step to x step on bob, com g203 to com on output bob.
c23 bob is set to com=+5v via jmp1 jump for gecko drive g203 drive
here is my screen shots maybe someone will see a issue
« Last Edit: June 14, 2009, 11:38:10 AM by eloid »
Offline eloid
  •  33 33
« Reply #11 on: June 14, 2009, 11:33:11 AM »
under vista  the driver test  wave look crapy, so i can ignore that?, im current run wim 2k no noise isuues with wave form
(ger21)
"The Smoothstepper handles everything. No need to optimize the PC with the Smoothstepper. And no need to run the drivertest."
« Last Edit: June 14, 2009, 11:34:54 AM by eloid »
« Reply #12 on: June 14, 2009, 11:41:39 AM »
Yes, ignore it. It's not being used.
Offline ticoe
  •  12 12
« Reply #13 on: July 03, 2009, 03:28:43 PM »
help i need plenty of it      New ss, New cnc4u C11, new geckos 320s, everything is Rosy.  Well not rarely   Z is perfect X and Y are all over the place they seem stronger in one direction and weak in the other , theykeep triping the geckos in one direction only
