Hello Guest it is October 21, 2026, 12:14:40 PM
Author Topic: LATHE: TOOL PATH SCREEN: APPEARANCE OF STOCK  (Read 17113 times)
« on: June 11, 2009, 06:14:06 AM »
I have just started using turn and have a current version loaded.  My question has to do with the tool path screen.  What controls the appearance of the stock?  On my screen, the stock does not appear or coincided with the tool path.
Jeff
Re: LATHE: TOOL PATH SCREEN: APPEARANCE OF STOCK
« Reply #1 on: June 11, 2009, 06:17:33 AM »
Can you post your code or a screenshot of what you are seeing.
Turn needs a fair bit of work, its never really had much attention in the past as people with lathes have been in the minority. Having said that, after Brian gets the new rev he is working on done he will be moving his attention to turn.
« Reply #2 on: June 11, 2009, 07:09:44 AM »
ATTACHED IS A SCREEN SHOT AND THE CODE:
O00001 (PROGRAM NUMBER)
(PROGRAM START - TURNING CYCLES)
(PROGRAM NAME - PRACTICE6.NC)
(POST - MACH 3)
(DATE - WED. 06/10/2009)
(TIME - 07:50PM)
N01 G18 G20 G40 G80 G90 G98
(JOB 1  ROUGH CYCLE )
(TOOL #1 80 DEG. 1/64 ROUGH TURNING )
N02 T0101 M06
N03 G50 S3000
N04 G96 S500
N05 G00 G54 X-.55 Z.0539 M08
N06 G01 X-.525 F5.
N07 Z-.4194
N08 X-.5433 Z-.4377
N09 X-.5446 Z-.4389
N10 X-.55
N11 G00 Z.0539
N12 X-.525
N13 G01 X-.5
N14 Z-.3944
N15 X-.525 Z-.4194
N16 G00 Z.0539
N17 X-.5
N18 G01 X-.475
N19 Z-.3749
N20 X-.4837 Z-.3784
N21 X-.5 Z-.3944
N22 G00 Z.0539
N23 X-.475
N24 G01 X-.45
N25 Z-.3748
N26 X-.475
N27 G00 Z.0539
N28 X-.45
N29 G01 X-.425
N30 Z-.3748
N31 X-.45
N32 G00 Z.0539
N33 X-.425
N34 G01 X-.4
N35 Z-.3747
N36 X-.425
N37 G00 Z.0539
N38 X-.4
N39 G01 X-.375
N40 Z-.3747
N41 X-.4
N42 G00 Z.0539
N43 X-.375
N44 G01 X-.35
N45 Z-.3747
N46 X-.375
N47 G00 Z.0539
N48 X-.35
N49 G01 X-.325
N50 Z-.3693
N51 X-.35 Z-.3745
N52 G00 Z.0539
N53 X-.325
N54 G01 X-.3
N55 Z-.3577
N56 G03 X-.325 Z-.3693 R.086
N57 G00 Z.0539
N58 X-.3
N59 G01 X-.275
N60 Z-.3353
N61 G03 X-.2994 Z-.3574 R.1115
N62 G00 X-.3 Z.0539
N63 X-.275
N64 G01 X-.25
N65 Z-.0246
N66 X-.2501 Z-.2628
N67 G03 X-.275 Z-.3353 R.1099
N68 G00 Z.0539
N69 X-.25
N70 G01 X-.225
N71 Z.0056
N72 X-.2461 Z-.0156
N73 X-.25 Z-.0246
N74 G00 Z.0539
N75 X-.225
N76 G01 X-.2
N77 Z.0306
N78 X-.225 Z.0056
N79 G00 Z.0539
N80 X-.2
N81 G01 X-.1901
N82 Z.0416
N83 X-.1904 Z.0402
N84 X-.2 Z.0306
N85 G00 Z.0539
N86 X-.19
N87 G01 Z.0412
N88 X-.1904 Z.0402
N89 X-.2 Z.0306
N90 G00 X-.35
N91 Z-.3745
N92 X-.349
N93 G01 Z-.3747
N94 G00 X-1.
N95 Z1.
N96 G40
N97 T0100
N98 M09
N99 M05
(END OF PROGRAM)
N100 M02
« Reply #3 on: June 11, 2009, 10:36:19 AM »
Jeff,
What program are you using to generate the code?
Can you post the DXF?
I can't find a setting that will get the stock to show properly and have seen similar before.
I have just ignored the stock at times by turning off the setting in config>toolpaths, not saying that is appropriate.
« Reply #4 on: June 11, 2009, 11:04:10 AM »
Rich,
I used BobCAD v23 to generate the code, first drawing the part in AutoCad, then importing it into BobCAD for the code generation.
« Reply #5 on: June 11, 2009, 12:40:18 PM »
It just looks like one of the problems with Turn, hopefully the revamp will get done soon and things will be well. Why some files show correctly and others dont I have no idea.
« Reply #6 on: June 11, 2009, 05:18:29 PM »
Sorry, just a user like yourself and don't know why.
I usualy do a final  finish / profile coding ( which the posted code dosn't seem to have ) and then maybe it "may" show correctly.
Until whenever, as long as it cuts the way you want it to.  ???
