Hello Guest it is September 16, 2026, 06:21:34 PM
Author Topic: PMDX 122/106 mach setup?  (Read 9720 times)
« on: June 09, 2009, 08:04:58 PM »
Hello,
I have a SmoothStepper, PMDX 122 BOB and a 106 spindle board. The board has the remote pannel interface and the spindle starts both directions and the POT controlls the speed just fine.
The 122 also drives my axis motors fine and works good. However I can not get Mach to send a PMW or start the spindle.
I have read the manual and checked my wirring multiple times and tried every setting I can think of in mach.
I am using the step as 16 and the dir as 14 and PMW is selected for spindle options, I am using pully 4 set-up 0-4000 RPM.
I have the charge pump options on the board selected and have it set-up as Pin 17
I am sure the VFD is wired correct and the board drives it fine in manual.
Is there something I am missing?
