Hello Guest it is November 11, 2026, 01:35:04 PM
Author Topic: jog and run from closest  (Read 13427 times)
Offline Bill_O
  •  616 616
« on: June 08, 2009, 07:30:04 AM »
I do not know if this is possible but it would be nice to be able to jog to an area near a toolpath and then do a run from here instead of scrolling back through the program.
Bill
Re: jog and run from closest
« Reply #1 on: June 08, 2009, 07:58:06 AM »
And have Mach3 guess where you want to start? Don't quite follow you. :)
Offline Bill_O
  •  616 616
« Reply #2 on: June 08, 2009, 08:22:31 AM »
I am not totally out in left field on this one. I know that at least one router manufacturer is able to do this.
If I am running a job and the bit breaks, after replacing the bit if I jog to the last area that had a cut I want Mach to start at the closest line to where the machine physically is.
Bill
« Reply #3 on: June 08, 2009, 08:29:50 AM »
Ever use the "Run From Here" button?
Offline Bill_O
  •  616 616
« Reply #4 on: June 08, 2009, 09:21:09 AM »
Yes and it works great.
What I want to do is from my pendant jog to a location near the cut that was interrupted (broke bit, lunch break or ???) and run from the closest line of gcode. I do not want to go back to the computer and scroll back through the file to find the point I wish to run from.
Bill
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #5 on: June 28, 2009, 09:26:18 PM »
I could write the code to do this but it would be paid time ;)
Offline Bill_O
  •  616 616
« Reply #6 on: June 29, 2009, 08:43:54 AM »
Zealous,
Thanks for the offer but it is not that important. If Brian could do this as part of the next Mach I would like it. Please Brian :).
Bill
