Hello Guest it is November 22, 2026, 03:11:50 PM
Author Topic: mach3 screen looks bad  (Read 12627 times)
Offline c+c
  •  17 17
« on: June 04, 2009, 12:28:06 PM »
Hello,
I try to run Mach3 on a Asus eee touch computer.
When running Mach3 with standard screen set, it looks awfull.
I think the attached picture speaks for ifself.
Labels are sometimes so big, that they do not fit in the space available for it.
It makes a lot af the labels unreadable.
Do I have to configure Window XP somehow?
« Last Edit: June 04, 2009, 12:30:08 PM by c+c »
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: mach3 screen looks bad
« Reply #1 on: June 04, 2009, 12:34:36 PM »
Couple things that will work:
-Resize the DRO's in Screen4 to the resolution of the monitor.
-changing your Font size in Windows to small
-Change the font type of the DRO's in Mach
-Use a Flash screen (they are vector based and will scale to any size shape and look clear)
Offline c+c
  •  17 17
« Reply #2 on: June 04, 2009, 01:11:04 PM »
But the screen set I used is ment for 1024*768. And my screen has 1366*768. So that will fit (with a empty space right to the window as you can see).
So I guess I should not change anything at the Mach3 settings.
I assumed the Windows fontsize was set to default, but I checked again. It was large!
So, Thanks! This solved it.
