Hello Guest it is November 28, 2026, 06:37:19 AM
Author Topic: Laser Cut Gaskets using a low power laser.  (Read 14321 times)
  •  9,379 9,379
« on: June 04, 2009, 10:00:55 AM »
My favorite model plane has an aging OS 61 which is now due for new crankshaft bearings and a clean up. The new crankcase gaskets have always been a pain to make (can’t buy them anymore – people don’t still use engines this old) and as I saw a posting recently about laser cut gaskets I decided to give it a try. I scanned the crankcase and got a reasonably good image which I converted to vector and then to GCode. Cutting at only 40 mm/min the 150mW laser made a pretty good job and didn’t set fire to the thin material as I half expected it to.
A couple of pictures of the laser and it’s control box on my Z axis, the finished gaskets and where they fit on the crankcase.
« Last Edit: June 04, 2009, 10:12:17 AM by Tweakie.CNC »
Re: Laser Cut Gaskets using a low power laser.
« Reply #1 on: June 04, 2009, 12:22:29 PM »
Tweakie,
Very nice!! I know it's a pain to cut a form from rubber. Now it's rather fun for you. Well done!
What's the material?
Daniel
  •  9,379 9,379
« Reply #2 on: June 04, 2009, 01:43:09 PM »
Hi Daniel,
It's the rust preventing paper that they use to wrap up tools etc. None of my proper gasket material is thin enough for this job.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #4 on: June 05, 2009, 12:09:34 AM »
Hi, Tweakie
Nice Job, Just need a little more Candle Power.
Chip
