Hello Guest it is November 01, 2026, 10:13:43 AM
Author Topic: Missing chain in G-code  (Read 13306 times)
« on: June 03, 2009, 03:46:24 PM »
Hello,
This is my first experience with lazy cam. I'm trying to get a simple DXF (created in illustrator) into gcode. Everything looks great in LazyCam, but it only sends a few of the chains to Mach3. Any suggestions?
-Christopher
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Missing chain in G-code
« Reply #1 on: June 03, 2009, 05:41:08 PM »
Hi, Christopher
Try these 2 G code files, What ver of Lcam are you using.
Chip
« Reply #2 on: July 14, 2009, 04:54:22 AM »
Hi Chip!
I have a similar problem as ojibberish. I wrote a simple text ("ShopZ.hu") in CorelDraw11. I export the file as .dxf. I import the file in LazyCam. The LazyCam recognize it, I see the text in the program. But when I want to make the G-Code the LazyCam doesn't make the whole G-Code of the "Shopz.hu".
I am using Windows XP Professional, SP3; CorelDraw11.633; LazyCam 3.00.2; Mach3 Demo Version R3.042.020.
I attach the dxf file and the wrong tap file; please, have a look at it.
What could be the solution? Should I reinstall the LazyCam and the Mac3?
Thank You:
Zoltan Szabo.
« Reply #3 on: July 14, 2009, 06:20:41 AM »
ROCKO86,
See the attached file. Just a quick and dirty for the steps I did from beginning to end.
RICH   ;)
Offline Chip
  •  2,055 2,055
« Reply #4 on: July 14, 2009, 01:00:57 PM »
Hi, Zoltan
Hears what I get, It looks fine, Make sure your using LCam 3.00.2 and these Setup, Loading Options.
Chip
« Reply #5 on: July 15, 2009, 10:15:36 AM »
Hey Guys!
It works fine! Thank you very-very much!
Of course, the demo version only handle the first 500 lines, but right now it is enough for testing. If everything works fine, I promise that I will buy a full license. ;)
Thank you again, keep up the good work!
