Hello Guest it is October 16, 2026, 12:25:39 AM
Author Topic: MACH 3 lockup  (Read 12660 times)
MACH 3 lockup
« on: June 02, 2009, 12:13:40 AM »
Everything worked fine until I began to play with the jogging pendant(tab)
now jogging has stopped working and the DRO wont zero etc.
Brian.
Re: MACH 3 lockup
« Reply #1 on: June 03, 2009, 02:03:18 AM »
please attach your xml.
Re: MACH 3 lockup
« Reply #2 on: June 03, 2009, 04:09:11 AM »
Thanks Hood I've fixed it.
Brian.
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: MACH 3 lockup
« Reply #3 on: June 03, 2009, 08:38:42 AM »
Brian, care to share how you fixed it? That helps other folks out who may experience the same problem at some point in time.
Happy machining , Jeff Birt
