Hello Guest it is October 20, 2026, 03:07:22 PM
Author Topic: Surfacing Wizard - Mach 3  (Read 19706 times)
« on: January 02, 2006, 09:01:06 PM »
Hello all,
I have lurked long enough here and really hope this forum format takes off.
I'm hoping for a bit of clarification. I purchased Mach2 and have now moved to Mach3. To be honest I have not done a lot with it as I'm in the process of building another machine. My first machine is limited by table size.
My query is around the surfacing wizard. In Mach2 I had the option to select the units mm/inch. This seems to be missing on the Mach3 version. Unless it's staring me in the face and I'm missing it !
Can someone please clarify this. I'm a metric only person and really struggle with those inches !
Re: Surfacing Wizard - Mach 3
« Reply #1 on: January 03, 2006, 05:10:40 AM »
The wizard will use the native units to run the program. So if you have your machine set up in mm it will run the program in mm.
Hope that helps
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: January 03, 2006, 10:35:24 AM »
Brian,
Many thanks. That clears up my query.
Just need to give it a go soon.
