Hello Guest it is November 13, 2026, 05:45:35 PM
Author Topic: missing library files in g100IO sample plugin  (Read 8508 times)
« on: May 29, 2009, 03:45:23 AM »
I downloaded g100IO sample plugin source and when I tried to compile it using Visual Studio 2005 (Professional Edition), it gave following errors even though there is a MachIncludes folder:
fatal error C1083: Cannot open include file: 'g100.h': No such file or directory
fatal error C1083: Cannot open source file: '..\g100library\src\G100Enumerator.cpp': No such file or directory
fatal error C1083: Cannot open source file: '..\g100library\src\G100Handler.cpp': No such file or directory
fatal error C1083: Cannot open source file: '..\g100library\src\G100Helpers.cpp': No such file or directory
It seems that the source doesn't have the g100library.
Please help !
Thanks in advance
Offline smurph
  •  1,575 1,575
Re: missing library files in g100IO sample plugin
« Reply #1 on: June 17, 2009, 12:36:11 AM »
It doesn't matter.  You won't be able to compile a working plugin with VS2005 anyway.  :(  You have to use VS2003.  Or there is a beta "framework" (for lack of a better description) that you can make a new plugin with VS2008.
Steve
