Hello Guest it is November 19, 2026, 06:59:01 AM
Author Topic: G Code Help  (Read 24369 times)
Offline AJA
  •  26 26
G Code Help
« on: May 26, 2009, 08:05:08 PM »
I want to run this code 50 times and increment it in the Y axis in 0.100 increments.  How do I accomplish this?
AJ
G00 X0 Y0 Z1
G01 Z0 F20
G18
G02 X-4 Z0 R3.4019
G17
G00 Z1
vmax549
Re: G Code Help
« Reply #1 on: May 26, 2009, 08:48:55 PM »
#2=0
M98 P100 L50
M30
o100
#1=.100
G00 X0 Y#2 Z1
G01 Z0 F20
G18
G02 X-4 Z0 R3.4019
G17
G00 Z1
#2=[#2+#1]
M99
Offline AJA
  •  26 26
Re: G Code Help
« Reply #2 on: May 27, 2009, 06:48:24 PM »
Thanks vmax549,
Will you recommend a book which provides and explains examples in line by line form for the various g codes?  I use the Mach 3 user's guide but for a newbee it leaves some holes in the examples.
Thanks again
AJ
vmax549
Re: G Code Help
« Reply #3 on: May 27, 2009, 08:26:13 PM »
I can explain the above code if that helps,  what you were asking for went a little above basic Gcode(;-).
A good read is PeterSmid's    "CNC Programing, second edition"  BUT it can be quite a read for a beginner  BUT it does have a help CD encluded.  I still use it as a referrnece from time to time.
He does a good job of explaining.
IF you need a BASIC learner there is one on the WEB I'll try and track it down again and let you know.
THe book is:
Easy CNC - A Beginners Guide to CNC
I have NOT read it myself but it does come recommended(;-)
« Last Edit: May 27, 2009, 08:42:26 PM by vmax549 »
Offline AJA
  •  26 26
Re: G Code Help
« Reply #4 on: May 29, 2009, 06:39:58 AM »
I understand the code as written, but noway would I have been able to place the lines in their correct order.
I have ordered both of the books which you recommended.  Perhaps some of their knowledge will be absorbed.
Thanks again
AJ
Re: G Code Help
« Reply #5 on: July 17, 2009, 03:36:18 PM »
I was taught to always use a % sign at the beginning  & the end of the program does this hold true for mach3
vmax549
Re: G Code Help
« Reply #6 on: July 17, 2009, 05:11:08 PM »
Not required but a good habit to be in.
Re: G Code Help
« Reply #7 on: July 19, 2009, 03:01:16 AM »
In some instances, mach does indeed need the carriage return. The "%" is just a visual cue that the carriage return (or whatever it's called nowadays) is actually there. Definitely a good habit to be in.
Re: G Code Help
« Reply #8 on: July 24, 2009, 07:06:20 PM »
...if you need help decoding G-Code....
I wrote a web based G-Code commenter.  It adds plain English comments to G-Code.
http://www.eng-serve.com/cnc/gcode_comment.html
Input
Code: [Select]
#2=0
M98 P100 L50
M30
o100
#1=.100
G00 X0 Y#2 Z1
G01 Z0 F20
G18
G02 X-4 Z0 R3.4019
G17
G00 Z1
#2=[#2+#1]
M99
It returns...
Code: [Select]
#2=0 ( #: Variable Assignment:#2=0 )
M98 P100 L50 ( M98:Call subroutine P:Line Number:100  L:Number of repititions:50 )
M30 ( M30:End program...rewind stop )
% ( %: Start or end of program )
o100 ( O:Subroutine label number:100 )
#1=.100 ( #: Variable Assignment:#1=.100 )
G00 X0 Y#2 Z1 ( G00:Rapid positioning #: Variable Assignment:#2 Z1 )
G01 Z0 F20 ( G01:Linear interpolation F:Feedrate:20 )
G18 ( G18:X-Z plane sel )
G02 X-4 Z0 R3.4019 ( G02:CW circular interpolation R:Arc radius:3.4019 )
G17 ( G17:X-Y plane sel )
G00 Z1 ( G00:Rapid positioning )
#2=[#2+#1] ( #: Variable Assignment:#2=[#2+#1] )
M99 ( M99:Return from subroutine )
Offline Fastest1
  •  920 920
  • Houston, TX
Re: G Code Help
« Reply #9 on: October 14, 2009, 02:45:01 PM »
Wow thanks for the commenter. That is quite helpful.
