Hello Guest it is November 08, 2026, 03:01:50 AM
Author Topic: Toolpath Display  (Read 18966 times)
Toolpath Display
« on: May 20, 2009, 03:14:55 PM »
My tool path display shows the tool path but does not show the movement as the code is run like it use to. Any ideas on what to look for.
Re: Toolpath Display
« Reply #1 on: May 20, 2009, 03:24:40 PM »
Has this just happened? Have you upgraded recently?
Have a look at the toolpath settings from the Config menu.
« Reply #2 on: May 20, 2009, 03:31:36 PM »
Don't know when it happened, just noticed it. I really don't look at that part of the screen to much. It is a customized screen. I loaded the regular 1024 screen and it does the same thing. Looked at the tool path settings but don't know what the defaults are for those. I am using version 3.042.
« Reply #3 on: May 20, 2009, 03:34:29 PM »
can you attach your xml and I will see what it looks like here.
« Reply #4 on: May 20, 2009, 03:41:39 PM »
Here is the xml file
« Reply #5 on: May 20, 2009, 03:43:03 PM »
This will also happen if you use a G92 as the actual tool movement will be offset by the difference between the original tool zero and the new tool zero.
« Reply #6 on: May 20, 2009, 03:47:36 PM »
Ok on the toolpath options check Tool Position, see if that helps, you may also want the origin sphere and maybe machine boundaries.
« Reply #7 on: May 20, 2009, 03:49:36 PM »
There is no G92 in the code....
« Reply #8 on: May 20, 2009, 03:55:21 PM »
Hood,
Checking the Tool Position, looks like that took care of it. It now works with my modified and the original 1024.set file.
Thank you
« Reply #9 on: May 20, 2009, 03:57:01 PM »
great, I like the easy ones to fix :)
