Hello
Guest
it is
November 13, 2026, 05:55:17 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
PoKeys
(Moderator:
NeoTO
z axis
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: z axis (Read 21585 times)
Bill_O
616
z axis
on:
May 19, 2009, 09:01:25 AM »
How do I set up PoKeys to use an analog input for the Z axis?
Bill
Logged
borisz
220
Re: z axis
Reply #1 on:
May 19, 2009, 09:29:43 AM »
User manual is your friend:
http://www.poscope.com/uploads/files/PoKeys55.pdf
Page 7
regards
Boris
Logged
www.poscope.com
home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
Bill_O
616
Re: z axis
Reply #2 on:
May 19, 2009, 09:36:52 AM »
Boris,
Analog input only gives the choices of X, Y , RotX, RotY and Throttle. No Z axis.
Bill
Logged
borisz
220
Re: z axis
Reply #3 on:
May 19, 2009, 09:41:22 AM »
Use one of that axis instead of Z.
What aplication needs Z axis on joystick? I did not seen Z axis on jostick.
regards
Boris
Logged
www.poscope.com
Bill_O
616
Re: z axis
Reply #4 on:
May 19, 2009, 10:10:00 AM »
Boris,
I am using a joystick for the x and y. I want to use a spring return pot for the z axis.
Bill
Logged
borisz
220
Re: z axis
Reply #5 on:
May 19, 2009, 10:24:21 AM »
Can you use one of that axis: RotX, RotY and Throttle
Z Axis is not supported now.
regads
Boris
Logged
www.poscope.com
Bill_O
616
Re: z axis
Reply #6 on:
May 20, 2009, 06:49:10 AM »
Boris,
In Mach I have x,y,z,a,b and c axis. Which one is rotx and roty?
Bill
Logged
borisz
220
Re: z axis
Reply #7 on:
May 20, 2009, 06:52:37 AM »
Now it is clear. We are talking about apples and peaches
PoKeys is joystick emulator and axes on PoKeys are emarked as on Joysticks.
My opinion is that you can assign any joystick axis to any Mach axis.
regards
Boris
Logged
www.poscope.com
Print
Pages:
1
Go Up
« previous
next »
