Hello Guest it is November 01, 2026, 03:37:11 PM
Author Topic: Trouble getting Autocad DXF into Lcam  (Read 32926 times)
Re: Trouble getting Autocad DXF into Lcam
« Reply #10 on: May 19, 2009, 07:38:47 PM »
Hello Chip,
     I did a off set around the drawn part in cad, I have4 been doing dummy runs on my home computer, and with some tweaking have managed to get a reasonable program, I'm now in the shop fiddling with my cnc computer, I will keep you posted,
.........Edmund...........
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #11 on: May 19, 2009, 09:04:21 PM »
Hi, Edmund
Sound's like your getting it sorted out.
Chip
« Reply #12 on: May 19, 2009, 10:19:34 PM »
Hello Chip,
     Can I ask you a question about another problem, it relates in a round about way, I wanted to download onto a CD the gcode I had developed and run in Mach3 on the home computer but it seems I am unable too, so I printed it off and typed it onto notepad on the shop cnc computer exactly and loaded it into Mach3 but it did not appear correctly, I have checked mach3 on the home computer and the working code against the print out and that is OK, yet the shop Mach screen is wrong,
Ant ideas?,
.................Edmund..........Alberta
Offline Chip
  •  2,055 2,055
« Reply #13 on: May 19, 2009, 11:43:26 PM »
Hi, Edmund
It needs to be saved as a ANSI format file, Sent you a PM message, Top of this screen your messages.
Chip
« Reply #14 on: May 22, 2009, 01:51:03 PM »
heres vthe dxf
« Last Edit: May 22, 2009, 02:02:56 PM by Chip »
