Hello Guest it is November 13, 2026, 07:39:42 PM
Author Topic: Disabling "MyNotify()" ID calls, of "Disabled" Plugins.........  (Read 8483 times)
I had noticed that if I had "Disabled" plugins in my plugin directory, that had Message ID functions listed under MyNotify(), that when I was using
my "Message Capture" plugin (in finished plugins). That those Plugin Mynotify functions WOULD REACT!!!!!
I have ALOT of plugins in my directory, I was testing the "NotifyPlugins(6000)" and a "Video Window" configuration opened., I have a Galil plugin that was
disabled, and I had tried 5000, well that launced one of the Galil notify functions......
So, I asked Art about it,  Here is the solution he gave me. I used it in the Capture Message Plugin, and the new MAD 3.7 (will get to my others later).
As a Global Variable Put:   bool PluginEnabled = false;
Art said, myPostInitControl() is only called if there is a Green Check for that plugin so...
void   myPostInitControl ()
   PluginEnabled = true;
                 /// rest of your code.
Then in myNotify(int ID)
void   myNotify ( int ID)
   if( !PluginEnabled) return;  //If false, it will jump out so any of your ID == # statements will not react
scott
Offline smurph
  •  1,575 1,575
Re: Disabling "MyNotify()" ID calls, of "Disabled" Plugins.........
« Reply #1 on: June 17, 2009, 12:41:50 AM »
I'll get that in the Galil Plgin ASAP Scott.  Thanks for the information!
Steve
« Reply #2 on: June 17, 2009, 06:58:02 AM »
NP,
  THANK YOU, for all the fantastic Galil work you have done!!!
Scott
