Hello Guest it is October 21, 2026, 03:55:12 AM
Author Topic: "SOFTLIMITS SYSTEM MOVEMENT ABORTED"  (Read 14956 times)
Offline Glenn
  •  129 129
« on: August 12, 2006, 07:52:12 PM »
 Hi All,
     This is the latest message across the message board as soon as I hit start on the second screen on Mach 3 Turn.
 Any ideas to correct this? This locks up any program that is loaded in to run.
                   Thanks for any ideas!
                             Glenn
Don't assume anything.....it'll make a Manager out of U and Me!
Re: "SOFTLIMITS SYSTEM MOVEMENT ABORTED"
« Reply #1 on: August 12, 2006, 09:29:48 PM »
if you are not using softlimits please disable them and it should fix your problem...
www.newfangledsolutions.com
www.machsupport.com
Offline Glenn
  •  129 129
« Reply #2 on: August 14, 2006, 04:42:14 PM »
Brian,
    Worked like a charm!.....Many thanks
Glenn
