Hello Guest it is October 31, 2026, 10:41:53 PM
Author Topic: How to change Reset button behaviour  (Read 8467 times)
« on: May 14, 2009, 07:07:11 AM »
With default Mach3 screen , pressing the "Reset" button causes shut down of all digital outputs to 0.
I wish this button to be a Reset for Mach3 and stopping any motion.
It should not shutdown any digital output.
Is there any other function which can meet my need.
From the Screen4 I could see this Reset button is connected to system Reset function and not clear what are all list of actions happening with this Reset function.Please point me if some document available.
All helps appriciated
sivaraj
Re: How to change Reset button behaviour
« Reply #1 on: May 14, 2009, 07:38:16 AM »
The RESET button is the sams as E-STOP and kills EVERYTHING as it should do and is intended to do.
FEEDHOLD will stop the axis motion in a position convienent for Mach to resume running the file.
STOP will stop motion immediately but can be abrupt enough to miss steps which may need re referencing of the axis's.
