Hello Guest it is November 07, 2026, 10:52:05 AM
Author Topic: XML Code  (Read 10021 times)
XML Code
« on: August 12, 2006, 09:40:52 AM »
Newbie Question.
Have a K2 2514 and the supplied xml code is only for Mach 2, since the video tutorials & documentation are excellent would really prefer to use the Mach 3.
Is there a way to convert or port the xml code?  Appreciate getting pointed in the right direction.
Comments, Suggests even cheap shots are all welcome.
Best
 Ron
Re: XML Code
« Reply #1 on: August 12, 2006, 12:05:56 PM »
No Mach3  will not work with Mach2 XML. You will have to set it up manually. It shouldnt be that hard as you can just write down all your settings from Mach2 and then shut it down and start Mach3 and enter all your port, pin etc settings. Once you have it running correctly copy the xml file and store it somewhere as a backup just in case you need it at a later stage.
 Also have a look at this thread, it may help you. http://machsupport.com/forum/index.php?topic=999.0
