Hello Guest it is November 13, 2026, 07:59:43 PM
Author Topic: mach 3 and thc 300 arc voltage setpoint  (Read 10552 times)
« on: May 13, 2009, 07:27:48 PM »
Hi all,
I have a plasma table running mach3 and the thc300 plugin.
Where is the proper location to set the arc voltage setpoint?? I have tried the
"tip volts" point under the settings page with no success. Does anyone know if this is the correct location to set your tip voltage ??
I am tried to trouble shoot if this is a THC issue or a Mach issue
thanks for any input in advance
