Hello Guest it is October 23, 2026, 04:11:14 PM
Author Topic: Mach 3 won't run under certain Laptop  (Read 14547 times)
« on: May 11, 2009, 09:41:58 PM »
I installed Mach 3 on my IBM X31 land an older HP aptop and it works perfectly but when I install it on my dell and T41 laptop it doesn't work.  I cannot use hot key to move the axis.  I also try to use the built-in wizard feature to generate some gcode and run it.  Still it won't run...(the X Y Z axis numbers were not changing)  Yes I have cleared the reset and I just don't know what's wrong with it
Re: Mach 3 won't run under certain Laptop
« Reply #1 on: May 12, 2009, 01:07:15 AM »
Some laptops will not run Mach but sounds like you may not have the Jog control switched on.
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #2 on: May 12, 2009, 08:26:33 AM »
Laptops are notorious for not running Mach properly. All the power saving features in a laptop prevent the precise timing that mach needs to operate properly. There is a document on the forum somewhere about optimizing a laptop for use with Mach. That may help but in my experience it still does not work as good as a desktop machine. If you set on using a laptop then I think your best bet is to use a SmoothStepper: http://soigeneris.com/Warp9.aspx . The SmoothStepper handles generating the precise timing pulses needed by the stepper motors (better than the LPT can) and lets Mach worry about trajectory planning and the UI.
Happy machining , Jeff Birt
