Hello Guest it is November 13, 2026, 08:05:25 PM
Author Topic: Any way I can get Mach to send me an email when it's finished?  (Read 16960 times)
Is is possible to hook up a bit of VB to M5 to send me an email letting me know mach has finished?
I can think about 6 ways to make a linux machine send me an email -  but windows and VB are a mystery...
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: Any way I can get Mach to send me an email when it's finished?
« Reply #1 on: May 12, 2009, 08:29:38 AM »
I'm not sure under the Cypress flavor of VB that mach uses. It can call other libraries though. I would do some googling on sending email in VB script or VB 6. That should be pretty close. I have some code around somewhere for VB.NET that I used for an introductory class on VB. If I can find it I'll post it.
I just found lots of info searching for 'VBscript send email', here is one:
http://www.activexperts.com/activmonitor/windowsmanagement/adminscripts/enterprise/mail/
« Last Edit: May 12, 2009, 08:34:57 AM by Jeff_Birt »
Happy machining , Jeff Birt
« Reply #2 on: May 12, 2009, 07:38:27 PM »
That looks similar to the code I found....
here's my new M5 script works when run manually - haven't tried it from a real job yet - obviously replace username, password, server, and email addresses. It's probably possible to omit the username and password but I don't have an email client setup on the computer running mach...
DoSpinStop()
Code "(sending mail)"
Const cdoSendUsingPort = 2 'Send the message using the network (SMTP over the network).
Set objMessage = CreateObject("CDO.Message")
objMessage.Subject = "mach finished"
objMessage.Sender = "youremail@blah.com"
objMessage.To = "youremail@blah.com"
objMessage.TextBody = "mach finished."
objMessage.Configuration.Fields.Item _
("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
'Name or IP of Remote SMTP Server
("http://schemas.microsoft.com/cdo/configuration/smtpserver") = "smtp.server.com"
'Type of authentication, NONE, Basic (Base64 encoded), NTLM
'objMessage.Configuration.Fields.Item _
'("http://schemas.microsoft.com/cdo/configuration/smtpauthenticate") = cdoBasic
'Your UserID on the SMTP server
'("http://schemas.microsoft.com/cdo/configuration/sendusername") = "username"
'Your password on the SMTP server
'("http://schemas.microsoft.com/cdo/configuration/sendpassword") = "password"
'Server port (typically 25)
("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = 25
'Use SSL for the connection (False or True)
("http://schemas.microsoft.com/cdo/configuration/smtpusessl") = False
'Connection Timeout in seconds (the maximum time CDO will try to establish a connection to the SMTP server)
("http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout") = 60
objMessage.Configuration.Fields.Update
objMessage.Send
« Reply #3 on: May 13, 2009, 09:37:02 AM »
Here's an idea...
Just mount a cellphone to the table, and at the end of your program have the spindle stop and rapid over to the phone and dial your number.  ;D
« Reply #4 on: May 13, 2009, 10:00:21 AM »
Neat idea !  :D
Would look good on YouTube too ! ;D
« Reply #5 on: May 13, 2009, 08:26:45 PM »
HAHAHA!!! I got a good laugh outta that one. Thanks.
« Reply #6 on: May 13, 2009, 08:36:03 PM »
 ;D
