Hello Guest it is November 11, 2026, 02:19:27 PM
Author Topic: Overhaul of Wizard Selection Menu  (Read 7424 times)
« on: May 10, 2009, 08:40:14 PM »
A couple of things would make this menu a lot nicer and more useful:
-  MRU list at top.  Often, one wants to go right back to the Wizard they were just using.  This is particularly painful on Wizards you have to scroll to get to (like Newfangled!).  It would be great to be able to see the last 3 Wizards accessed at the top of the menu so you could immediately pick one.
-  Let it size larger if the screen allows.  It requires a lot of scrolling by default.
I looked a little bit at trying to write a VB script to do this.  Doesn't look easy because I couldn't see a way to load the list of folders in the add-on directory so I could build a menu.
Cheers,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
