Hello
Guest
it is
November 13, 2026, 08:05:54 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
reverse cut lathe wizard
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: reverse cut lathe wizard (Read 10571 times)
KC
3
on:
May 09, 2009, 02:20:36 PM »
Is there a lathe wizard for cutting the reverse direction? (Spindle to TailStock) The current wizard will not let you define a cut that way.
Logged
Carnoustie, Scotland
Re: reverse cut lathe wizard
Reply #1 on:
May 09, 2009, 02:27:36 PM »
You could probably use G51Z-1 at the start of the code to reverse it then G50 to reset. I use that when I am using the front toolpost on my lathe to reverse the X axis as the rear turret is my default.
Logged
Print
Pages:
1
Go Up
« previous
next »
