Hello Guest it is October 29, 2026, 08:20:59 AM
Author Topic: Default Hotkeys list  (Read 38323 times)
« on: May 09, 2009, 01:11:37 PM »
This is the present default Mach screens hotkeys list. It will be changeing at some point, probably with the release of the 4.0 version. Generating this list would have been nearly impossible without Klaus's Machscreen Screen designer. Many thanks to Klaus for his work on this. The designer can be found at Klaus's website. A link to his website is posted in this message in a topic about his designer  http://www.machsupport.com/forum/index.php/topic,11122.msg69909.html#msg69909
Notes: The list can be sorted by screen type, Hotkey, Function, and Page it is called from. Text in red means the same hotkey calls more than one function in the same screen set.
I hope this helps,
« Last Edit: May 10, 2009, 09:10:27 AM by Chaoticone »
