Hello Guest it is October 28, 2026, 09:23:16 AM
Author Topic: what is missed at this brain?  (Read 8587 times)
« on: May 07, 2009, 02:15:46 PM »
This works fine...
[OEMTRIGGER#1]---->[No-Operation/Pass Signal]---------------------------------------->[        ]
[OEMTRIGGER#2]---->[No-Operation/Pass Signal]---------------------------------------->[                     Formula                                  ]
[OEMTRIGGER#3]---->[No-Operation/Pass Signal]---------------------------------------->[  F=( a*1 )+( b*2 )+( c*4 )+( d*8 )+( e*16 )  ]------->[No-Operation/Pass Signal]->[VR0]
[OEMTRIGGER#4]---->[No-Operation/Pass Signal]---------------------------------------->[        ]
[OEMTRIGGER#5]---->[No-Operation/Pass Signal]---------------------------------------->[        ]
[VR0]--------------------->[No-Operation/Pass Signal]---------------------------------------->[Compare Imm.  I=1]---------------------------------------------->[Jog On/Off]
When I add one more line it crash Mach3 and i need restart PC  ???
[OEMTRIGGER#1]---->[No-Operation/Pass Signal]--------------------------------------->[        ]
[OEMTRIGGER#2]---->[No-Operation/Pass Signal]--------------------------------------->[                     Formula                                   ]
[OEMTRIGGER#3]---->[No-Operation/Pass Signal]--------------------------------------->[  F=( a*1 )+( b*2 )+( c*4 )+( d* 8 )+( e*16 )  ]------->[No-Operation/Pass Signal]->[VR0]
[OEMTRIGGER#4]---->[No-Operation/Pass Signal]--------------------------------------->[        ]
[OEMTRIGGER#5]---->[No-Operation/Pass Signal]--------------------------------------->[        ]
[VR0]--------------------->[No-Operation/Pass Signal]--------------------------------------->[Compare Imm.  I=1]----------------------------------------------->[Jog On/Off]
[VR0]--------------------->[No-Operation/Pass Signal]--------------------------------------->[Compare Imm.  I=2]----------------------------------------------->[Spindle On/Off]
Thanks in advance for any help.  :)
Re: what is missed at this brain?
« Reply #1 on: May 11, 2009, 03:33:18 PM »
Read the "Brians users guide" I wrote in memeber documents, it notes there are issues with trying to use Vars from out put to input side more than once.
Brian, is aware of the many Brain issues, and at some point he will get to fixing them......
scott
« Reply #2 on: May 13, 2009, 01:38:57 AM »
scott
I stopped using Mach3 Brains, I did the work using macropump.
Tank you Scott for the answer and forgive my joke... but Mach 3 has a brain of amoeba. :)
