Hello Guest it is October 24, 2026, 04:11:41 AM
Author Topic: Floating head dives in to material  (Read 13105 times)
Offline mrpeja
  •  114 114
    • Embroidery Machines
« on: May 06, 2009, 09:02:33 AM »
When I cut a hole, (arc lead -in and -out) head touches material at the end of cut. I have Anti dive ON, Pierce height 5mm, Cut height 3mm  and Thc300  corrections Max=20mm and Min=-10 mm.
What is wrong?
Please advise
mrpeja
Re: Floating head dives in to material
« Reply #1 on: June 09, 2010, 09:33:17 AM »
Hello,
Sorry if this message resurrects this old post, but I have the same problem using Sound Logic's THC300D and Hypertherm Powermax 1250 being controlled by Mach3 (plasma mode)
Tried to leave anti dive on and off and the same occurs - torch insist to dive and touch material at the end of cut.
I hope someone can give me a clue.
Fabio Gilii
« Reply #2 on: June 09, 2010, 09:48:26 AM »
Sorry for the "bump"
Found another thread where seems a colleague solved the problem using a "brain" solution.
http://www.machsupport.com/forum/index.php/topic,8202.msg56660.html#msg56660
Offline mrpeja
  •  114 114
« Reply #3 on: June 09, 2010, 10:19:10 AM »
Hi guiacnc,
 I had this problem with holes, when piece falls down. I solved this by "none lead out" for holes in SheetCam
mrpeja
« Reply #4 on: June 09, 2010, 11:34:36 AM »
Mrpeja,
I had the same idea - to eliminate the "leadout" part...
Today we are using Lazycam - Will use Sheetcam too!
Thanks and best regards.
« Reply #5 on: June 09, 2010, 07:19:27 PM »
YEP do not use the leadout with an inside cut. When you get back to the CUT area to do the leadout the large open space causes the tip voltage to rise and the THC see this and lowers the tip to try to maintain the preset voltage level.
Also with the leadout the torch may loose arc and shut mach down as well.
