Hello Guest it is November 15, 2026, 10:03:57 AM
Author Topic: Z-Safe position  (Read 11119 times)
Offline Psad
  •  82 82
Z-Safe position
« on: August 10, 2006, 12:42:15 PM »
Still having a problme with the "GOTO Z".
I have z safe progrmed as + .500" (setting screen), top of material is set for 0.0,  cuts are made at -.25.  When I hit "go to Z" the cutter dioes not raise first.  X&Y complete first, Am I using th co ordnate system wrong. ???
Re: Z-Safe position
« Reply #1 on: August 10, 2006, 03:34:18 PM »
The safe Z is machine coordinates so if your Z goes from 0 to minus then you can not have a positive for the safe Z as it would be above the fully home position. Set your safe Z to 0 or less and it should work, I have mine at -5mm and it works perfectly.
Re: Z-Safe position
« Reply #2 on: August 10, 2006, 08:24:01 PM »
Also... go to the config menu and select 'logic'  make sure the 'use safe Z' box is checked.  If it's not, check it and relaunch Mach 3
Sid
