Hello Guest it is November 13, 2026, 08:07:44 PM
Author Topic: need help step per unit  (Read 30327 times)
« on: May 05, 2009, 11:53:01 AM »
I've read tuning motor chapter,and make my calculation as below
pitch=1/5 =0.2                effective pitch =0.2x2=0.4
screw revs per unit =1/0.4 =2.5
motor revs per unit= 2.5xNs/Nm=2.5x1 =2.5    (1:1 drive ratio because my gear has no teeth)
mach3 steps per motor revs =200x32 = 6400
mach3 step per unit = 6400x2.5 =16000
would you please check this calculation if it right and if drive ratio 1:1 is right or not.
thank you for your support
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: need help step per unit
« Reply #1 on: May 05, 2009, 12:04:26 PM »
You have a 32 microstep drive?
You also have a very low drive ratio which will give you very little torque. You are essentially direct driving a low pitch lead screw.
Happy machining , Jeff Birt
  •  9,377 9,377
« Reply #2 on: May 08, 2009, 11:01:20 AM »
Hi elgammmmal,
Are you working in mm or inches here.
« Reply #3 on: May 08, 2009, 11:16:52 AM »
hi Tweakie
thank you for your interest  and my machine  set up  in mm .
« Reply #4 on: May 08, 2009, 11:54:25 AM »
You are working in mm and it takes 2.5 revolutions of your screw to go 1mm?   Is that correct?
« Reply #5 on: May 08, 2009, 12:21:53 PM »
             My guess is a 5 TPI double cut thread. 0.2" pitch, 0.4" lead.
             2.5 turns per inch
             Assuming 1:1..........Don't understand "Toothless Gear".
             32 microstep
            Looks right to me but the units look to be INCHES
RC
« Last Edit: May 08, 2009, 12:23:57 PM by Overloaded »
« Reply #6 on: May 08, 2009, 02:58:28 PM »
My guess is 5mm = .2" approx twinstart = 8mm .4" approx
             32 microstep
6400/8 = 800 steps
Phil
« Reply #7 on: May 08, 2009, 04:53:35 PM »
.in mach 3 guide says (if the motor has a gear ,chain or belt drive to the screw with Nm teeth on the motor gear and Ns teeth on the screw gear then motor revs per unit = screw revs per unit xNs/Nm).my motor has gear with belt drive to the screw the gear is flat with no teeth so how can I calculate Nm and Ns.shall I ignore Nm and Ns in my calculation or there is anther way to calculated.
thank your for kind support
« Reply #8 on: May 08, 2009, 05:02:31 PM »
Are you meaning you have pulleys and a belt but they are smooth with no cogs ?
That would be odd for an axis drive train.
If so...  measure the OD of each pulley. Then divide the driven pulley dia by the drive pulley dia. That will be the ratio.
If they are the same OD it will be 1:1.
« Reply #9 on: May 08, 2009, 05:10:05 PM »
If they are timing pulleys, just count the teeth on each pulley. Then divide.
Is this the type you have ?
« Last Edit: May 08, 2009, 05:16:41 PM by Overloaded »
