Hello Guest it is November 17, 2026, 04:20:47 PM
Author Topic: Screenset installation  (Read 14414 times)
« on: May 04, 2009, 12:17:40 PM »
Hi all,
Yet another problem.
I have downloaded a screen set with the extension .m3s
When i double click it asks what program do i want to use to open it
Any clues
I did a search but nothing showed up
This is the one "Blue Screenset for Lathes"
Phil
Re: Screenset installation
« Reply #1 on: May 04, 2009, 12:46:03 PM »
Where did you get that? screensets should have extensions of either .set, .sset, .lset or finally if its a flash screen then swf
« Reply #2 on: May 04, 2009, 01:32:35 PM »
From the download section  ;D
Forgot to add it is not seen in Mach because its the wrong file type
According to the heading as per the picture double clicking it should self install
Phil
« Last Edit: May 04, 2009, 01:40:43 PM by Phil_H »
« Reply #3 on: May 04, 2009, 01:41:00 PM »
ah ok, looks like there is such a beast after all, similar I would think to the m3p of the plugins. What version of Mach do you have as it has to be newer than 1.90. If you have that then what you could try is when you double click and it asks what you want to open with browse and choose M3plug.exe.
« Last Edit: May 04, 2009, 01:46:09 PM by Hood »
« Reply #4 on: May 04, 2009, 02:09:53 PM »
A ha, some idiot moved that file on my computer thinking it was some unneeded plug-in.
I have now moved it back again and the screenset installed as it should, when it has all the files available
Well done to Hood
Phil
