Hello Guest it is November 01, 2026, 02:19:50 PM
Author Topic: macro works under mach3 editor but not by gcode or mcode  (Read 8312 times)
« on: May 03, 2009, 11:04:15 AM »
Hello .
This program should perform testing of the limits of drawing, and record them in a file.
the program works well only from the editor.
Xmax= GetOEMDRO (10)
Ymax= GetOEMDRO (11)
message "X"&Xmax &"Y"&ymax
XYposition="X"&Xmax &"Y"&ymax
sleep (100)
code "g90 G00 "& XYposition
While Ismoving()
Wend
sleep (500)
code "g90 G00x0y0 "
While Ismoving()
Wend
Open "c:\XYposition.txt" For Output As #1
Write #1,XYposition
sleep (100)
Close #1
'End
vmax549
Re: macro works under mach3 editor but not by gcode or mcode
« Reply #1 on: May 06, 2009, 08:51:42 AM »
DOUBLE check that you have saved the file in the proper directory. It should go to c:\mach3\macros\machmill  (If you are in mill).
I ran it from Mcode AND a button here.
I also changed your code around  a bit.
While Ismoving()
Sleep(100)
Wend
code "g90 G00x0y0 "
While Ismoving()
Sleep(100)
Wend
Write #1,XYposition
Close #1
End
