Hello Guest it is October 20, 2026, 03:01:28 PM
Author Topic: How can one use a PLC in CNC?  (Read 16544 times)
« on: April 30, 2009, 04:59:13 PM »
I an an electrician and have some PLCs laying around. Anyone know how these could be used in CNC apps, mainly X-Y tables? which I have two of.
I'm thinking PLCs could be used for additional inputs and outputs, motor speed etc.
 I saw this post and PLCs used here:-
http://www.machsupport.com/forum/index.php/topic,5536.0.html
regards,
Shane Dwyer, AU
Re: How can one use a PLC in CNC?
« Reply #1 on: April 30, 2009, 05:08:39 PM »
If your PLC has modbus you can use it with Mach for extra I/O, tool changers etc. I have one on my lathe and it did the gear change routine for my spindle (now have AC servo), the toolchange for 6 position turret, 4 position toolpost, worked the chuck, coolant and loads of I/O for buttons and servo drives.
« Reply #2 on: April 30, 2009, 05:11:19 PM »
Oh also if your PLC has analogue inputs you can use them for FRO and SRO.
« Reply #3 on: April 30, 2009, 08:44:13 PM »
If the PLC has a pulse output, or a motion module it can also run a tool changer motor totally independant of Mach....so I have read.
Barfeeders, pick and place too.
Leaving Mach more freedom to run the part program.
RC
« Reply #4 on: May 01, 2009, 09:41:24 AM »
mine is operating a 12 position tool changer operating a total of 5 relays , a brake and monitering a total of 14 prox sensors and as soon as I iron out the details will also be operating the automated tool setting probe
« Reply #5 on: May 01, 2009, 06:33:03 PM »
regards,
Shane Dwyer, AU
Hi Shane,
I'm not sure what you want to do with a PLC, but to get some idea of what can be don't with Modbus devices, have a look through the ModIO manual at;
http://homanndesigns.com/store/index.php?main_page=product_info&cPath=2&products_id=4
Also check out the Wiki at;
http://www.machsupport.com/MachCustomizeWiki/index.php?title=Mach3_Pendants_links
http://www.machsupport.com/MachCustomizeWiki/index.php?title=Main_Page
Cheers,
Peter.
Homann Designs
http://www.homanndesigns.com
