Hello Guest it is September 28, 2026, 09:20:10 AM
Author Topic: Sub within a Sub ?  (Read 23653 times)
Sub within a Sub ?
« on: April 29, 2009, 07:26:53 AM »
  Just experimenting.....can a sub run within a sub ?
This sample code executes nicely for however many duplicates requested in the X.
#3=0
M98 P01 L4
G0 X0 Y0
M30
 O1
G0 X#3
G1 z-.2 F50
G03 I-1.
G0 z.1
#3=[#3+2.3]
m99
Can I run this sub IN another sub that shifts the Y in the same manner ?
Say.....4 rows and 4 columns ?
I've made several attempts wit no sucess.
RC
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Last Edit: April 29, 2009, 05:56:34 PM by Graham Waterworth »
vmax549
Re: Sub within a Sub ?
« Reply #2 on: April 29, 2009, 06:33:58 PM »
I think Mach can do 3 levels as long as you do NOT recall a currently running sub. Don't hold me to it though(;-) Post what you tried and I will test it as well.
Nothing like an adventure, (;-) TP
« Reply #3 on: April 29, 2009, 07:57:28 PM »
Hey Graham......GREAT links. I wish I'd seen them while searching.
They are very helpful...Thanks. Found some others too.
I especially liked the tapping grid you illustrated.
I guess that is the "Three Levels" that Tony just mentioned.
Hi Tony,
    Not enough band width to post what I have tried...lol
Another question,
        The grid looks great for tapping or drilling but what if I were making a multi cavity mould of say a star.
The datum of the star would be the center, so the shifts are OK so would the star program, with x-y moves, be the last sub running in G91 ?
Or would you use another approach.....like G52 instead ?
Hope this makes sense to ya.
RC
vmax549
« Reply #4 on: April 29, 2009, 08:14:00 PM »
Here is a sub in a sub drilling 10 rows of ten holes
G0 x0y0z0
g91
M98 P1 L5
g80
G90
M30
o1
g81 z-.1 R.1 F20
x1 L9
y1
x-1L9
g80
M98 P2 L0
o2
Y1
m99
m99
« Reply #5 on: April 29, 2009, 10:21:52 PM »
Mighty handy there TP...amazing how much can be done with so little code.
How would you go about making a grid of a part program ?
Like this one attached for example.
4 rows, 8 columns
RC
  •  2,785 2,785
« Reply #6 on: April 30, 2009, 03:01:52 AM »
If I were doing multi pockets then a calculated G52 local shift would be my method.
Graham
« Reply #7 on: April 30, 2009, 06:12:25 AM »
Graham, Tony,
  This runs well in simulation.
m98 p0001
G52 x5
X0
m98 p0001
g52 x10
X0
m98 p0001
G52 x15
X0
m98 p0001
G52 x20
X0
m98 p0001
G52 X0
X0
m30
Is this a proper way to use G52 ?
Thanks guys,
RC
vmax549
« Reply #8 on: April 30, 2009, 08:54:52 AM »
RC Graham is correct the g52 would be a good choice. With a drilling CYCLE it is very easy to work in incremental, BUT when you shift to doing a shape then INC becomes a bear to keep track of and the G52 shift becomes the favorite venue.
Also note that there are MANY ways it can be done, BUT sometimes Mach struggles with complex subs. I just did one to do a shape in a grid using parametric code  4x4 grid of a simple square. It was funny that mach could draw it out on the toolscreen correctly but could NOT cut it correctly.
Also just because it is crazy complicated DOESN"T mean it is the best approach the simple ways are normally the BEST ways to programming
Just a thought, (;-) TP
« Last Edit: April 30, 2009, 09:35:40 AM by vmax549 »
vmax549
« Reply #9 on: April 30, 2009, 10:55:10 PM »
RC it displays correct but can't say it would actually cut correct(;-)
N5 (File Name = ARING on Wednesday, April 29, 2009)
N10 (Default Mill Post)
N15  G91.1
#1=0
#2=0
N20 M5 M9
N25 M6 T33(TOOL Change .125 End Mill)
N30 G43 H33
N35 G0  Z0.2000
N40 M3 S4000
M98 P10 L4
M98 P11 L9
M30
o10
N45  X-0.5000  Y0.0000
N50  Z0.1000
N55 G1  Z-0.0300  F50.00
N60 G2  X0.5000  Y0.0000  I0.5000  J-0.0000  F100.00
N65  X-0.5000  Y0.0000  I-0.5000  J0.0000
N70 G0  Z0.2000
N75  X-1.0000  Y0.0000
N80  Z0.1000
N85 G1  Z-0.0300  F50.00
N90 G2  X1.0000  Y0.0000  I1.0000  J-0.0000  F100.00
N95  X-1.0000  Y0.0000  I-1.0000  J0.0000
N100 G0  Z0.2000
N105  X-2.0000  Y0.0000
N110  Z0.1000
N115 G1  Z-0.0300  F50.00
N120 G2  X2.0000  Y0.0000  I2.0000  J-0.0000  F100.00
N125  X-2.0000  Y0.0000  I-2.0000  J0.0000
N130 G0  Z0.2000
N135  X0.3214  Y0.3830
N140  Z0.1000
N145 G1  Z-0.0300  F50.00
N150  X0.2595  Y0.4443   F100.00
N155  X0.2042  Y0.5122
N160  X0.1552  Y0.5857
N165  X0.1125  Y0.6638
N170  X0.0448  Y0.8292
N175  X0.0000  Y1.0000
N180  X-0.0205  Y1.1233
N185  X-0.0337  Y1.2477
N190  X-0.0411  Y1.4987
N195  X-0.0279  Y1.7504
N200  X0.0000  Y2.0000
N205 G0  Z0.2000
N210  X0.3420  Y0.9397
N215  Z0.1000
N220 G1  Z-0.0300  F50.00
N225  X0.6840  Y1.8794   F100.00
N230 G0  Z0.2000
N235  X0.4924  Y0.0868
N240  Z0.1000
N245 G1  Z-0.0300  F50.00
N250  X0.4844  Y0.1735   F100.00
N255  X0.4856  Y0.2611
N260  X0.4954  Y0.3489
N265  X0.5128  Y0.4362
N270  X0.5674  Y0.6064
N275  X0.6428  Y0.7660
N280  X0.7762  Y0.9775
N285  X0.9319  Y1.1745
N290  X1.1037  Y1.3588
N295  X1.2856  Y1.5321
N300 G0  Z0.2000
N305  X0.8660  Y0.5000
N310  Z0.1000
N315 G1  Z-0.0300  F50.00
N320  X1.7321  Y1.0000   F100.00
N325 G0  Z0.2000
N330  X1.9696  Y0.3473
N335  Z0.1000
N340 G1  Z-0.0300  F50.00
N345  X1.7189  Y0.3315   F100.00
N350  X1.4688  Y0.3007
N355  X1.3451  Y0.2781
N360  X1.2229  Y0.2498
N365  X1.1027  Y0.2152
N370  X0.9848  Y0.1736
N375  X0.8244  Y0.0998
N380  X0.6732  Y0.0045
N385  X0.5398  Y-0.1121
N390  X0.4826  Y-0.1784
N395  X0.4330  Y-0.2500
N400 G0  Z0.2000
N405  X0.9848  Y-0.1736
N410  Z0.1000
N415 G1  Z-0.0300  F50.00
N420  X1.9696  Y-0.3472   F100.00
N425 G0  Z0.2000
N430  X1.7321  Y-1.0000
N435  Z0.1000
N440 G1  Z-0.0300  F50.00
N445  X1.5298  Y-0.8510   F100.00
N450  X1.3185  Y-0.7138
N455  X1.2092  Y-0.6516
N460  X1.0974  Y-0.5947
N465  X0.9830  Y-0.5439
N470  X0.8660  Y-0.5000
N475  X0.6957  Y-0.4534
N480  X0.6076  Y-0.4382
N485  X0.5186  Y-0.4293
N490  X0.4296  Y-0.4273
N495  X0.3415  Y-0.4329
N500  X0.2550  Y-0.4469
N505  X0.1710  Y-0.4698
N510 G0  Z0.2000
N515  X0.6428  Y-0.7660
N520  Z0.1000
N525 G1  Z-0.0300  F50.00
N530  X1.2856  Y-1.5320   F100.00
N535 G0  Z0.2000
N540  X-0.1710  Y-0.4698
N545  Z0.1000
N550 G1  Z-0.0300  F50.00
N555  X-0.0919  Y-0.5062   F100.00
N560  X-0.0167  Y-0.5511
N565  X0.0545  Y-0.6035
N570  X0.1214  Y-0.6622
N575  X0.2415  Y-0.7946
N580  X0.3420  Y-0.9397
N585  X0.4034  Y-1.0485
N590  X0.4584  Y-1.1610
N595  X0.5512  Y-1.3943
N600  X0.6249  Y-1.6352
N605  X0.6840  Y-1.8794
N610 G0  Z0.2000
N615  X0.0000  Y-1.0000
N620  Z0.1000
N625 G1  Z-0.0300  F50.00
N630  Y-2.0000   F100.00
N635 G0  Z0.2000
N640  X-0.6840  Y-1.8794
N645  Z0.1000
N650 G1  Z-0.0300  F50.00
N655  X-0.5724  Y-1.6544   F100.00
N660  X-0.4740  Y-1.4224
N665  X-0.3951  Y-1.1840
N670  X-0.3649  Y-1.0626
N675  X-0.3420  Y-0.9397
N680  X-0.3257  Y-0.7639
N685  X-0.3261  Y-0.6745
N690  X-0.3327  Y-0.5853
N695  X-0.3462  Y-0.4973
N700  X-0.3670  Y-0.4115
N705  X-0.3958  Y-0.3287
N710  X-0.4330  Y-0.2500
N715 G0  Z0.2000
N720  X-1.2855  Y-1.5320
N725  Z0.1000
N730 G1  Z-0.0300  F50.00
N735  X-0.6427  Y-0.7660   F100.00
N740 G0  Z0.2000
N745  X-1.7321  Y-1.0000
N750  Z0.1000
N755 G1  Z-0.0300  F50.00
N760  X-1.5019  Y-0.8994   F100.00
N765  X-1.2774  Y-0.7849
N770  X-1.0637  Y-0.6530
N775  X-0.9626  Y-0.5794
N780  X-0.8660  Y-0.5000
N785  X-0.7405  Y-0.3758
N790  X-0.6311  Y-0.2345
N795  X-0.5848  Y-0.1584
N800  X-0.5456  Y-0.0793
N805  X-0.5145  Y0.0026
N810  X-0.4924  Y0.0868
N815 G0  Z0.2000
N820  X-1.9696  Y-0.3472
N825  Z0.1000
N830 G1  Z-0.0300  F50.00
N835  X-0.9848  Y-0.1736   F100.00
N840 G0  Z0.2000
N845  X-1.6426  Y0.2566
N850  Z0.1000
N855 G1  Z-0.0300  F50.00
N860  X-1.4831  Y0.2198   F100.00
N865  X-1.3591  Y0.1987
N870  X-1.2346  Y0.1835
N875  X-1.1098  Y0.1749
N880  X-0.9848  Y0.1736
N885  X-0.8972  Y0.1782
N890  X-0.8088  Y0.1882
N895  X-0.7208  Y0.2040
N900  X-0.6342  Y0.2260
N905  X-0.5498  Y0.2546
N910  X-0.4689  Y0.2900
N915  X-0.3924  Y0.3327
N920  X-0.3214  Y0.3830
N925 G0  Z0.2000
N930  X-1.9696  Y0.3473
N935  Z0.0000
N940 G1  Z-0.0300  F50.00
N945  X-1.7286  Y0.2764   F100.00
N950  X-1.6426  Y0.2566
N955 G0  Z0.2000
N960  X-1.7320  Y1.0000
N965  Z0.1000
N970 G1  Z-0.0300  F50.00
N975  X-0.8660  Y0.5000   F100.00
N980 G0  Z0.2000
N985  X-1.2856  Y1.5321
N990  Z0.1000
N995 G1  Z-0.0300  F50.00
N1000  X-1.1465  Y1.3229   F100.00
N1005  X-0.9948  Y1.1217
N1010  X-0.8278  Y0.9342
N1015  X-0.7377  Y0.8473
N1020  X-0.6428  Y0.7660
N1025  X-0.4987  Y0.6640
N1030  X-0.4211  Y0.6196
N1035  X-0.3405  Y0.5808
N1040  X-0.2576  Y0.5484
N1045  X-0.1728  Y0.5236
N1050  X-0.0868  Y0.5071
N1055  X0.0000  Y0.5000
N1060 G0  Z0.2000
N1065  X-0.3420  Y0.9397
N1070  Z0.1000
N1075 G1  Z-0.0300  F50.00
N1080  X-0.6840  Y1.8794   F100.00
N1085 G0  Z0.2000
       X0 Y0 Z0
N1090 M5
g92 x[#1+5]
m99
o11
G92 y[#2+5] X[#1-15]
M98 P10 L4
M99
