Hello
Guest
it is
November 13, 2026, 10:00:00 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
manually set machine zero
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: manually set machine zero (Read 11199 times)
evsourcef
1
on:
April 28, 2009, 04:50:16 PM »
I'm having problems with the x axis limit switch on my cnc. The y and z work fine but the x is not working. Is there a way to manually set machine zero on an axis? I know how to do that for running a code but I like to have softlimits on and if the machine zero is off it will stop running a code when it gets to what it thinks is zero.
Any help?
Carnoustie, Scotland
Re: manually set machine zero
Reply #1 on:
April 28, 2009, 05:45:32 PM »
Disable the home switch in Ports and Pins for that axis and when you home the axis will be set to zero at whichever position it currently is, so if you jogged near the end of travel it would set machine zero there.
Print
Pages:
1
Go Up
« previous
next »
