Hello Guest it is November 19, 2026, 06:04:47 AM
Author Topic: Drilling in Mach3 and PMPost postprocessor  (Read 23559 times)
jeffpower14
« on: August 08, 2006, 08:03:05 AM »
I was wondering if anyone could tell me anything about writing g-codes for drilling with mach3.  I read the post about peck drilling, but what about the code for other types of drilling?  Can mach 3 do helical drills?
I need this because I am trying to make a postprocessor for PMPost to generate g code from powermill.  Is anyone else here using powermill or PMPost?  Does anyone already have a postprocessor for PMPost?
Re: Drilling in Mach3 and PMPost postprocessor
« Reply #1 on: August 08, 2006, 09:11:31 PM »
We only do helical Milling ...
You can have up to 6 axis at the same time...
www.newfangledsolutions.com
www.machsupport.com
jeffpower14
« Reply #2 on: August 09, 2006, 08:14:02 AM »
So what does a line of g-code to do a helical drill look like?  I don't see it in the Mach manual or in the list of g-codes in mach3.
« Reply #3 on: August 09, 2006, 12:43:24 PM »
Just a series of G2 or G3's. Here's a 1/4" hole using a 1/8" tool. 1/8" depth of cut perr pass. 1/2" deep.
G0 Z0.1250
G0 X0.1250 Y0.1875 Z0.1250
G1 X0.1250 Y0.1875 Z0.0000 F10
G2 X0.1250 Y0.1875 Z-0.1250 I0.0000 J-0.0625 F20
G2 X0.1250 Y0.1875 Z-0.2500 I0.0000 J-0.0625
G2 X0.1250 Y0.1875 Z-0.3750 I0.0000 J-0.0625
G2 X0.1250 Y0.1875 Z-0.5000 I0.0000 J-0.0625
G0 Z0.25
« Last Edit: August 09, 2006, 01:45:24 PM by ger21 »
jeffpower14
« Reply #4 on: August 09, 2006, 03:55:51 PM »
To drill a single peck hole I write
g81 x~ y~ z~ r~
x and y the point, z the depth and r the clear plane height.
Is there an equivalent for helical drills? a helical drill canned cycle?  I don't think there is, I'm just looking to confirm my suspicions.
Thanks for the replies
« Reply #5 on: August 09, 2006, 06:01:08 PM »
I don't think so. All the supported codes are in the manual.
http://www.machsupport.com/documentation/M3M1_84-A2.pdf
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #6 on: August 10, 2006, 03:04:21 AM »
What do you class as a helical drill?.
What is the application?.
post a picture or a web link of the tool you are talking about.
Graham.
