Hello
Guest
it is
November 24, 2026, 08:06:54 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Arc wizard
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Arc wizard (Read 10888 times)
geoff3881
46
Arc wizard
on:
April 25, 2009, 04:37:17 AM »
I wonder if anyone can help on a minor matter ? I have been using the arc wizard to cut a semi circular recess with a bull nose cutter. Everything is fine and I am working in the XY plane.
I now want to cut in the XZ plane and have edited the G code to do this and it works OK.
Question :- Can you get the arc wizard to generate the G code for other planes directly ?
Logged
Carnoustie, Scotland
Re: Arc wizard
Reply #1 on:
April 25, 2009, 06:12:07 AM »
Dont think it can, you could alter the VB to output it that way, you could even copy it all changing the VB and save it so you have two wizards.
One other option may be to just have a VB Button that would swap axis.
Logged
Print
Pages:
1
Go Up
« previous
next »
