Hello Guest it is November 13, 2026, 03:00:39 AM
Author Topic: Is Pokeys affected by CPU speed  (Read 14851 times)
« on: April 24, 2009, 04:30:58 PM »
I have setup my Pokeys for Feed control with a potentiometer
It is quick changing feedrate when there is no program running but very very slow when running a program.
It will not change until the program's line has finish to execute.
Any advice?
Re: Is Pokeys affected by CPU speed
« Reply #1 on: April 24, 2009, 07:38:44 PM »
Mine is as fast when running code. What version of Mach do you have? Are you using a SmoothStepper?
My CPU is an AMD Athlon 2500+
« Reply #2 on: April 24, 2009, 09:43:36 PM »
I'm not using SS
Mine is an old 1GHz CPU with two parallel bob
I use the latest version of Mach3, 3.041
It is a brand new install
Here's some preview picture of my pendant, I'm not finish yet the labelling of all button, some more design to do
Jogging button have two function, when pushing the probing mode button, they can be use to probe in all direction, including Z- else, they are use to jog.
The white led indicate jogging mode and the red indicate probing mode and the probing mode button is illuminated when in use, as a warning
All button are illuminated when they are pushed
I'm still working on illuminating Cycle start, Pause, Stop, and Reset only when they are on, I want Cycle start button to be illuminated only when there's a program running
I will have to modify the probing mode button to enter automatically in the offset page, but for now it work great
The HOME, DEF ALL AXIS, TOOL HEIGHT, CYCLE START, STOP work great, I still have to work on the FEEDHOLD button, not working
I can toggle between screen 1 and 5, as well as the TAB screen and toggle cont/step
« Reply #3 on: April 25, 2009, 04:48:19 AM »
Looks good :)
