Hello Guest it is November 21, 2026, 03:17:17 PM
Author Topic: New control computer, cant get dsp software to work.  (Read 25174 times)
« on: April 22, 2009, 04:13:28 PM »
I dropped an I beam on my computer and its done.
I had my config files backed up on a flash stick, unfortunately that was on the side of the computer at the time and it got messed up too.
Anyways, replaced the head and went to re-install the software with no success.
I installed the dspMC software and tried to run the hardware ugrade tool so I could pull the config off the motion controller but I cant run either of the dsp programs. I get the error message:
"This application failed to start because the applications configuration is incorrect. Reinstall may fix the problem"
I reinstalled and restarted and no fix. I tried my old version of the dsp software as well as the new version. Any ideas why the software wouldnt run on a normal XP computer?
« Last Edit: April 22, 2009, 04:17:01 PM by vitalsystem »
Re: New control computer, cant get dsp software to work.
« Reply #1 on: April 22, 2009, 04:22:51 PM »
looks like you need to install the attached windows package.
regards
Rufi
