Hello Guest it is November 19, 2026, 04:40:31 AM
Author Topic: Improved tool path display ( see video)  (Read 18212 times)
ynneb
Re: Improved tool path display ( see video)
« Reply #1 on: August 06, 2006, 06:30:23 AM »
I like it  . but is it possible to enlarge the toolpath display  , let's say full screen ?
ynneb
« Reply #2 on: August 06, 2006, 07:57:47 AM »
Yes the screen designer will allow you to create a full screen display if you want.
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #3 on: August 06, 2006, 04:46:41 PM »
Great screen, I'm using it now and it adds allot to the machine experience.
Thank you ;D
One quick questions and one problem:
Is it possible to add a diffrent color to the toolpath when there is multiple pass. I sometimes find my self coming back to the machine an hour later not sure which pass it's on. Not a big deal.
I have been using the new screen all of today, and loaded many diffrent toolpaths, but for some reason one of my G-code files is not refreshing in the new screen. When loading the attached g-code file and rotating the view in the screen gives me ghosting and freezes up Mach.
I have test the same file on two diffrent computers with  Mach3 Dev. Version 1.90.051 and the file work fine.
I have tested the file on two diffrent computers with Mach3 Dev. Version 1.90.071  and both have the same problem.
Can any one verify this and give me a hint at what I'm doing wronge. See attachment
-Thanks
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #4 on: August 06, 2006, 05:58:57 PM »
Hi, zealouse
There is a bug in .071 Art seed he found the problem and it will be fixed in next Release.
Chip
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #5 on: August 06, 2006, 06:05:39 PM »
Thanks for the quick responce, I'll wait. The new features are great ;D
« Reply #6 on: August 06, 2006, 06:26:55 PM »
This new 4th axis toolpath was a TON of work from Art and I... Art and I both didn't know if we could make Mach3 do what we wanted it to do... But as you can see we did it! Art is getting to be a very good OpenGL programmer! I only play the small part of making math do what he needs...  Art is truly a great programmer!
www.newfangledsolutions.com
www.machsupport.com
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #7 on: August 28, 2006, 06:53:18 PM »
Just wanted to comment on how great the new toolpath screen is. ;D
The updated Mach is working great with no problems at all.
The new features and clarity are great.
If I can help with anything let me know.
